Johannes Hodne avatar image
Johannes Hodne asked
Firmware 1.56 issue - load output stopped working
Hello.
I have a smartsolar mppt 100/20. After I updated to 1.56 the load output stopped working. Tried always on, but no response.
Is there a way to downgrade the firmware?
Best regards Johannes
VictronConnectfirmware update
Hi @Johannes Hodne ,
I've asked a developer:
We need more info, there is no other complain so far.
What does 'stopped working' mean? is it always off? did you try / measure without anything connected?
You could try older firmware on https://professional.victronenergy.com/accounts/login/?next=/ .
There are also plenty of other things to check, like if the streetlight is on, if he sees the load state going to ON on the VC main page, etc
Johannes Hodne answered ·
Streetlight is off.
I have tried turning load output on without a load and with a low load connected (lightbulb) but load output stayed off and no measured voltage. The status display on the victron connect app state load output OFF all the time.
But if i give the load output a "jumpstart" (a momentary connection from the battery), the load output went on. And stated on in the victron connect app, showing current and power. Then I can turn load off from the app but not on again.
Could it be the output short circuit protection that's failing?
I couldn't find any older firmware than v1.56 on the link you gave me.
Sorry for my poor english
li-tech avatar image
li-tech answered ·
I have just had the exact same issue with a SmartSolar 100/20 but had already upgraded the new controllers to BT2.25 & v1.56.
Yesterday the controller wanted to upgrade from v1.56 to latest and afterwards the Load Turned Off and tried any setting on Load Output but still shows as Off with a 75% fully charged 12V battery and two 200W solar panels. 0V on Load Output.
Was working fine before the update as downloaded history etc.
The controller was still showing the solar panels charging.
