I have a caravan, using my Lifo4 100amph, if i use an inverter could i just plug it into a spare plug socket using a 3 pin plug to power up the other 3 pin sockets
Hi @Alan932
Please don't do that. You'd need to rig up what's often called a 'Suicide' lead. It needs exposed pins, and is aptly named. Please, nonono..
I can see what you want to do, and the el-cheapo way would be to wire in a plug to fit your shore power inlet, and plug it in there. Only if you have a single inlet though.
26 People are following this question.
