edvanz avatar image
edvanz asked
Stop charging and allow charging Skylla-i
I have a system with 2000Ah Winston cells, REC BMS, Cerbo GX 2x Quattro's, MPPT's and a Skylla-i. When the stop charging signal is given from the Cerbo the Quattro's stop charging but the Skylla-i keeps charging. Does anybody have an idea how to solve this. A dirty way is to use a relay connected from the REC BMS direct to switch off the Skylla-i but I want to use that only when I get above the max cell voltage.
cerbo gxVE.Can
Paul B avatar image
Paul B answered ·
there is no remote control that turns the Skyla off, the relay option is the only choice
