kking avatar image
kking asked
MPPT 100/30 producing 0 watts 0 amps
I set up my solar system a week ago and have not been able to receive any watts or amps from the system.
Setup:
2, 100 W panels wired in series
100/30 MPPT charge controller, wired to + and - bus bar
2, 200 AH AGM batteries - 1 year old
Victron battery monitor
The battery voltage will drop below 11V and the panels still do not produce any power. I have disconnected the wires and reconnected, checked all the connections, and checked the fuses on each end of the system. Here are some pictures of the current readings.
It also will read the battery voltage at 13.8V on the Smart Solar, but on the battery monitor it reads 10.8V.
battery chargingMPPT SmartSolarmppt charging
There are many other questions about this topic, please use the search function.
In most cases it's a bad/loose connection, open switch or a blown fuse somewhere between the MPPT and the battery.
wkirby avatar image
wkirby answered ·
It's almost certain that the battery is not connected to the MPPT for one of many reasons. This evidenced by your statement that the MPPT will show 13.8V (which is it's programmed target Voltage for Float) and the BMV is showing 10.8V. At night the BMV and MPPT most likely show the same battery Voltage.
You can see the difference in readings which would not be possible if both the MPPT and BMV were properly connected to the battery.
Connections may look OK but a high resistance terminal or connection can be decieving.
Check fuses, check that circuit breakers are actually operating and making a connection when closed. Check terminations are sound.
MPPT product page
VictronConnect manual
PWM or MPPT
MPPT calculator
MPPT codes
