benc987 avatar image
benc987 asked
Solar not charging or receiving voltage
I’m having an issue with my solar charger it’s a 100/50 mppt. I have checked all wiring including reversing the plus and negative solar into the mppt, I have removed the isolator switch and connected directly, I have checked all wiring connectors, I have checked all fuses etc yet still nothing. I understand it’s not been the sunniest days but surely it should read something. Also my pannels are 175w x 3 connected in series. The unit is on by the way and I can connect to it by Bluetooth. Any other thoughts? I’d there a setting somewhere that’s easy to miss as I am sure I have it set correctly.
battery chargingMPPT SmartSolar
Connecting the battery in reverse can have blown a internal fuse that is not changeable by the end user.
Make some screenshots of VictronConnect.
benc987 avatar image benc987 commented ·
Sorry just to clarify, It’s plus and negative from the pannels which Iv swapped around not from the battery.
MPPT product page
VictronConnect manual
PWM or MPPT
MPPT calculator
MPPT codes
