Mike Dorsett avatar image
Mike Dorsett asked
About Victron Configuration Assistants
I've just had a look at loading the PV inverter assistant on a fake system with VE configure. Whilst you can ste the nominal system voltage, and the precise frequency limits, you cannot set the precise voltage thresholds for this assistant nor can one determine exactly what they are. I did read somewhere in the notes that these limits are not related to the absorption and float voltages set elsewhere? It seems to me a necessary function of the assistant would be to work with customisable set points... for both frequency and voltage to allow for correct operation with different battery types. Is it possible to either get the source code for these assistants, or a document defining how to write one's own?
VEConfigure 3Assistants
