john-b avatar image
john-b asked
Is there a better way of running the AC Thor in off-grid application other than PV assistant?
In my off grid system I use an AC Thor 9S to run two 3kw immersion heaters when excess solar is available which the PV assistant controls by adjusting the charge settings in the inverter however it is very unreliable and the frequency shift to 53hz remains even when the batteries are down at 40%, it’s hit and miss if the frequency goes back to 50hz or not and it will drain my system if I’m not careful.
Battery is currently 60% and frequency 52.6hz, there is no logic to this.
Is there a better way to control this that’s more accurate?
Assistants
e-box avatar image
e-box answered ·
Hello #John B
My system (1-phase Off Grid) is also not working well. PV surplus is often not used at all.
And batteries are not charged higher than 80-90%!
Which frequency settings did you use in the PV-inverter Assistent?
Which settings did you use in the AC Thor?
Best regards,
Gabriel
