brianv avatar image
brianv asked
Autotransformer wiring for balancing loads, split phase 120/240
My AC source is split phase120/240. It supplies two hot wires and a ground, no neutral. I am using a Victron transformer because I am splitting the two phases into two separate battery chargers for my RV, but I need the loads on the two hot wires to remain balanced. My question is, would it be correct to connect the two hots AND the ground into the autotransformer, and then use the two 120 lines, the new neutral (created by AT), and ground coming from the autotransformer to connect to my loads (battery chargers)? Any potential issues with that set up?
wiringAutotransformersplit phase
wkirby avatar image
wkirby answered ·
If I understand your question correctly, then you would need to connect the Autotransformer as shown below.
1623564499383.pngAs always, have your electrician verify that the installation complies with your local codes and regulations.
