Yusef Neblett avatar image
Yusef Neblett asked
L1/L2 Multi+ measurement readings on a 230v Split Phase with Autotransformer
I have setup a 48/5K/70 Multiplus for a Home Split-Phase configuration, using the Autotransformer Diagram below where L1 is connected to the L1 on the Multi and L2 is connected to the N on the Multi and then using an Autotransformer to step down from 230v to 115v/115v
My question is: Is this taking the measurement that shows in CCGX and VRM from L1+L2 phases? is the value showing there is a total from L1 and L2, or it is only showing L1 (phase1)?
VRM shows data only for Phase 1 and not for phase 2
Autotransformersplit phase
wkirby avatar image
wkirby answered ·
Those measurements are being taken for current flowing out of the MultiPlus its self. It is the sum of L1 + L2. There are no current measurement sensors in the Autotransformer to allow separate L1 or L2 current.
Yusef Neblett answered ·
Hi WKirby,
Thanks for your answer. It is understandable that the readings are made by the multiplus and not on the transformer.
Since I am feeding the ACin from the grid with 2phases I was expecting to see phase 1 and phase 2 in separate reading. But looks like there is no way to configure 1 Multi to read and show the reading by phases.
