Rick avatar image
Rick asked
100/20 MPPT + 12-12/30 DCDC + Control Box Wiring Diagram
Hey all!
I’ve gotten myself into a little bit of a spaghetti of a mess trying to rely on my memory with everything coming in and out of the control box for my setup...
basically, all wiring and devices are mounted and wired in and out of the control box, making itself and the device easily removable if required because, both my 100ah deep cycle and the control box will be in the wheel well in the back of my Outback.
I’m hoping someone who is kind enough to help me out with putting together a diagram with the appropriate midi holders in place with what I’m trying to achieve here, I’ll be posting up photos shortly also with how far I’ve gotten so far.
Ultimate goal is to have it looking simple but, fully functional with the ability to show customers what’s possible as well as easy access to its fuses if required.
cheers and thanks all!
I’ll note that -
A. Yes I’ll have ventilation added through the box for the MPPT via a Load controlled fan.
B. I haven’t added a Anderson for the Auxiliary Battery as of yet to the box, however - it will be located on the opposite side to the Fridge output
MPPT ControllersOrion DC-DC Converters not smartinstallationmppt charging
