keit6473 avatar image
keit6473 asked
Why Does Generator Power Drop When Load Applied?
I have a Quattro 24/5000. When I add an AC load, the Quattro drops the AC 1 In current (connected to a 4800 W generator). The inverter/batteries make up the difference. See attached screen shot.
Settings: 120V, 60hz, Power Assist = on; Boost Factor = 2.0, max; AC 1 input current limit = 15 amps. See screen shots. The only difference in conditions in these two screen shots is the AC load applied.
powerassistinput current
@keit6473
Do you have weak ac checked? Or wide frequency enabled?
