damon-blumenstein avatar image
damon-blumenstein asked
Current limit at 15 but only using 10?
Anyone know why when I set the limit to 15amp, the Multiplus is only allowing 10-11amps and pulling the rest from battery? I tried 20amp but then the generator gets killed by the spike when AC kicks on. screenshot-20220805-214519-vrm.jpg
powerassistinput current
kevgermany avatar image
kevgermany answered ·
Is there a limit on the grid hookup?
Yes, it's at to 15, that's the problem, it's only pulling 10-11. Once the air condition turns off and the load isn't so high, it charges the battery with around 14 amps. Once the AC load is back, it drops back to 10-11A and pulls the rest from the battery.
