tilapia avatar image
tilapia asked
Other Touch screens not working on Cerbo GX
I have a Cerbo GX that I want to connect to a large touchscreen monitor. Research in this community suggests a generic monitor is possible in RPI, but can’t find info for the Cerbo GX. The monitor displays the GX data and menu, but the touch part does not work. Does anyone have way to recalibrate the new screen for use in the Cerbo?
gx device
Hi @Tilapia,
This answer is correct, the Cerbo GX does not support any other touch screens than the GX touch.
https://community.victronenergy.com/questions/63611/ceerbo-gx-enable-touch-for-larger-screen.html
It is possible to use USB accessories like a keyboard though.
tom4x avatar image
tom4x answered ·
This topic is discussed in https://community.victronenergy.com/questions/93218/generic-touchscreen-on-cerbo.html including solutions. Some 3rd-party touch screens work with Cerbo GX.
johanndo avatar image
johanndo answered ·
Yes, there is a touchscreen calibration utility, you can install it and calibrate the bigger touchscreen. You can have only one at a time connected, the Cerbo has only one HDMI output, and you need a USB data connection to the cerbo for the touch interface, the USB power port for the factory screen is not sufficient for this.
The calibration tool requires command line interactions, you need to boot the cerbo into the shell without a GUI and run the utility, then remove the headless file again and reboot back into the Gui. You need a keyboard connected via USB to the Cerbo to do this. Y
You may loose your warranty/support when modifying your system, so be aware of what you are doing.
