Is it possible that a VE Direct LoRaWAN measures the voltage from it's supply? If yes: does it transmit this voltage to the portal? This would allow to use it for remote monitoring the voltage without any other VE.direct capable device.
Hi @roochr !
I posted a message which described VE Direct to WLAN capability :
https://community.victronenergy.com/questions/33570/smartsolar-settings-for-vedirect-rx-tx-communicati.html
It uses cheap electronic modules... But it's running for more than a year now!
27 People are following this question.
