Is there a way to have, Voltage, Current from the DC Power and PV Charger
That information can be derived. Are you not happy with the values you see in terms of the totals? I think what you have there is a 52 W load with the PV Charger providing 19W and the Battery 33W for a total of 52 W into the load. The Vdc for all three items would be the same unless you have unacceptable voltage losses in your cabling. Given that you know the power the current can be calculated by dividing by the voltage.
i am no expert but just so happens that all the values tally up.
26 People are following this question.
