In order to maximise the output from a Victron Blue Smart IP65 24V 13 Amp Battery Charger, what AC input power is required @240v in watts ? The info is required so I can assess the size of generator required to run the charger remotely.
P = U x I
P = 28v (absorption voltage) x 13A
P = 364W + some conversion losses
P = should be around 400W at the AC input
The AC input current should be also printed on the device.
26 People are following this question.
