paulcooper avatar image
paulcooper asked
MPPT RS case interferes with the VE.Direct connector
I am using a Victron VE.Direct cable with my MPPT RS 450/100. The position of the MPPT case means that the cable plug won't fully seat home in the socket of the MPPT. More than once it has not made a connection between my MultiPlus II GX and the MPPT. This seems like a design flaw and could be rectified by making up my own cable rather than using the Victron cable. Alternatively I could cut away some of the case but would rather not do this. Any advice?
VE.Directmppt rs
Ingo avatar image Ingo commented ·
I haven't checked my own connection but it surely is a small oversight from the quality checkers if you ask me. I would shave off a bit of the connector if possible rather than making my own cable. The chassis mod seems to be the only longterm fix in my opinion.
paulcooper avatar image paulcooper Ingo commented ·
Thanks Ingo. This is what I decided to do instead of cutting the metal case. The VE.Direct plug now makes a good contact.
Hi, thanks for spotting this. An oversight indeed; not good.
We’ll fix it for future production. And indeed most likely by a change in the enclosure.
Matthijs
