marco1977 avatar image
marco1977 asked
Hello, I bought a VE.Direct LoRaWAN module (connected to an MPPT 100/20 and it flashes green) but the ID on the device is not accepted in the VRM portal. Why is that.
VRMHelpLoRaWAN
llubi avatar image
llubi answered ·
I had the same problem. Solution was to buy a Lora wan gateway and check the Victron Lora ID. In my module, ID was wrong. Used in the VRM the ID I saw in the gateway and worked perfect
