xylus avatar image
xylus asked
PPP 40Ah charging via high capcity output
I have a few questions about Peak Power Pack 40Ah charging via high capacity output in car.
1. I've try to charge my PPP via this output and initially, about 2 minutes, the current were above 50 amps, and then gradually decreased to 30 amps. Manual says 15-20 amps max. Voltage from car's alternator is 13,95V, but voltage drop in cables (4mm^2) made effective charging voltage 13,3-13,6V.
2. 50 amps is above 1C charging. Is this safe for PPP, cells and for me? - fire, big bang etc.
3. Is the BMS still active and cells are protected? Is charging terminated automatically after PPP is fully charged?
4. Car/Solar input of PPP is limited to 7 amps, so charging takes 6-7 houres and often is too slow.
battery charging
