joergd avatar image
joergd asked
Since the last firmware update of the MPPT 150/35 via the VictronConnect app, the controller disappears from the color control several times an hour.
It then takes a few seconds until it reaches full charging capacity again. Has anyone observed a similar behavior or even has a solution ready?
System Info: MultiPlus + MPPT 150/35 + ColorControl + Pylontech LiFePO4
MPPT SmartSolarCCGX Color ControlVictronConnect
Hello joergd,
Is the Color Control connected to VRM and is remote support enabled? If so, do you mind giving the site name so we can log in on the system to see what might be causing the problem?
Kind regards,
Thiemo van Engelen
