thuke82 avatar image
thuke82 asked
Port forwarding
I am an It Manager. I need to do a port forwarding for a Victron but I have some trouble. Customer ask me to forward port 80/81 TCP but it seems not enough. I see the home page but it answer "NOT CONNECT".
For network reason I can not forward external port on 80 and 81 but I need to do a NAT-T to 22001 and 22002 TCP external port.
Maybe we need also another port ?
Thansk
TCP IP Networking
markus avatar image
markus answered ·
I think that forwarding to another Port than 80/81 will not work, as the LAN Webinterface is somehow always redirected to Port 80/81.
Is your firewall capable of Dial Up VPN? If yes I would solve it this way.
Or just use Remote Console on VRM.
Best Regards,
Markus
thuke82 answered ·
Good evening, I solved problem by myself.
It's work.
It is possible to use every http port you want, but victron always answer on 81. I forced firewall to redirect answer to another port with a static route and I solve the problem.
So if you want to do a NAT-T on Victron, yon can.
