jjm avatar image
jjm asked
Phoenix Smart IP43 charger (1+1)
Hello all,
I have a question about the Phoenix Smart IP43 charger (1+1).
The 1+1 variant is supposed to offer two outputs.
Unfortunately, there is only one plus and one minus.
How is this supposed to work with the 2 outputs (starter and consumer battery)?
Thanks in advance
Jens
Phoenix Inverter
The +1 is the trickle charge connetion limited to 3A.
phillip-kent avatar image phillip-kent commented ·
two separate units in parallel.
jjm avatar image
jjm answered ·
Guten Morgen Matthias,
und wieder eine Antwort von dir.
Vielen Dank dafür.
Mmm, da ich einen Umbau mache, werde ich dann das vorhandene Kabel sicher nicht drunter bekommen und brauche ein neues Kabel.
Kannst du einen Tipp geben welcher Querschnitt das Kabel haben sollte?
Dann hätte ich auch gleich noch eine Zusatzfrage.
Gibt es Unterlagen, die mir die Anschlüsse (Bsp. Remote, wo die Brücke drin ist und Relay) erläutern?
Vielen Dank
Jens
wkirby avatar image wkirby ♦♦ commented ·
Trickle charge connector can accept cables 0.33mm² - 2mm².
Main terminals can accept cables up to 16mm²
Remote on / off operation is explained in the manual:
https://www.victronenergy.com/upload/documents/Phoenix_Smart_IP43_Charger_manual/Phoenix_Smart_IP43_Charger-en.pdf
jjm avatar image
jjm answered ·
Thank you wkirby...
But I didn't´t get it really.
In general the charger works with the shore connection.
If the shore connection is not there = no charging.
If I plug the shore connection in, I would expect that the charger is charging automatically.
Is it required to switch the charger separately on?
And pull H to plus or L to minus...
I don´t understand what is that for?
If you want to switch the charger on and off with shore power, that is no problem at all. In that case, leave the jumper in place like from the factory. The charger will work automatically as you expect.
The remote terminal provides additional functionality for anyone who needs it. For some other people it is useful to have the charger disabled by remote devices or by a BMS for example.
jjm avatar image jjm wkirby ♦♦ commented ·
Now, I understand.
Thank you very much.
hans-durivou avatar image
hans-durivou answered ·
Hi Matthias. I have the same unit. My question is why cant i see two separate battery banks?
Kind tegards
