dl1oli avatar image
dl1oli asked
Can I switch off my Multiplus 48/3000/35-50 with the cerbro GX?
Hello, is it possibke to swich of my Multiplus 48/3000/35-50 1920 with one of the relais in the Cerbro GX remotly?
MultiPlus Quattro Inverter Chargercerbo gx
You don't need to use a relay for that.
You connect the MultiPlus with a RJ45 cable via VE.Bus to the Cerbo.
The MP is than shown in the device list and from there you can switch it ON/OFF/Charger-only/Inverter-only.
dl1oli avatar image
dl1oli answered ·
Thank you. I thougth I had read about it, but could not switch it in the menu. Now, after your answer, I tryed more and discovered that "space-like" lower key must be used to get the screen to switch off.
Thanks
