Alexandru Piriiala avatar image
Alexandru Piriiala asked
Phoenix Inverter 12V 500VA Negative Current calibration
Hello i used the search button and this topic was already discussed, i can understand that the current measuring components in the inverter are not the best but i need to calibrate the reading via software if possible (VenusOS RP)
With no load the inverter reads -0.2A altering all the DC power readings adding 46W of loads and its really annoyng, i have some experience with linux but i don't know how i can add a +0.2A to the reading and what to edit.
I could also act on the board if there is something that can be done to calibrate it.
When the inverter was new the readings were good.
Thank you.
Phoenix Inverterinverter current draw
runar-borge avatar image runar-borge commented ·
Hi Alexandru!
I have the exact same issue as you, but didn't notice your post until after i posted my own post..
Anyways i've created a small workaround for this issue by not allowing the negative reading from the inverter to pass back to the total count. https://community.victronenergy.com/questions/87555/dc-power-shows-incorrect-consumption-on-unloaded-p.html , i would not consider this as a fully working fix until victron can fix its code, so consider it is a workaround for now...
Phoenix Inverter product page
Phoenix Inverter Smart product page
