dan-broad avatar image
dan-broad asked
Alternator control cable and Smart BMS Cl 12/100
Hello. Does anyone know if the https://www.victronenergy.com/cables/ve-bus-to-bms-12-200-alternator-control-cable
will work with the Smart BMS CL12/100?
I already have a VE.bus BMS connected to my Multi 3k, and would like to use only the current limiting functionality of the BMS CL12/100, and not have it connected to the Victron lithium battery bms cables.
Dan.
BMS
shlandrews avatar image shlandrews commented ·
I have the same question, was originally going to use the BMS12/200 but problem with common ground on boat.
frankcilo avatar image
frankcilo answered ·
Up, I'm also interested in the answer, do you have any news?
