spicedreams avatar image
spicedreams asked
connect BMV 700 by VE.Direct to EasySolar II GX- what more must I do?
I have already the EasySolar II GX and the BMV-700, both up and working but not connected to each other.
However I don't get State of Charge information in the Remote Console or VRM portal. The only place I get SoC is on the BMV-700 display.
Since both the EasySolar II GX and the BMV-700 have VE.Direct ports, I have bought a VE.Direct cable, hoping that if I connect them then I will start to see SoC remotely.
My questions:
1. Must I wait until the EasySolar is shut down before connecting the cable?
2. Once the cable is connected and EasySolar is back running, is there anything I need to do to get the two talking to each other?
3. Will connecting them in fact get me the benefit I am hoping for? Or is there something else I should be doing?
Thanks!
Graham
BMV Battery MonitorEasySolar All-in-OneVE.Direct
After connecting the BMV (no matter if the GX is ON or OFF) the BMV should appear in the device list and you have to check settings -> System Setup -> Battery monitor
seb71 avatar image
seb71 answered ·
After you have them connected, also read about DVCC and (if you have grid there) about ESS.
spicedreams avatar image spicedreams commented ·
No grid so no ESS.
I have read about DVCC a couple of times now (from pointers given by the community) and am no clearer what the benefit is. I can see it changes the system's behaviour, but does it put more energy into the batteries, or make them last longer?
