apple047 avatar image
apple047 asked
PV meter on the output of inverter data
I have an ESS running with Cerbo GX, Multiplus II, and an AC coupled inverter on the output of the multi. Until recently i didn't monitor PV production but today i installed an EM111 meter, it's communicating fine however I cant configure it that its connected on the output of the multi. I select the position of the meter "AC Output" but its reverting back to "AC Input 1" once the page refreshes.
This causes "AC Loads" calculations to be incorrect.
I did set up in ESS assistant the PV inverter on the output and by the looks of it the generation is being counted twice.
Thanks in advance for assistance
George
ESSEnergy MeterAC PV Coupling
apple047 answered ·
After a bit of reading it looks like i have the same problem as Thomas
https://community.victronenergy.com/questions/85166/consumption-is-showing-proportional-to-pv-inverter.html
wilga avatar image
wilga answered ·
Same problem here (Venus OS v2.90).
Solution: setting the meter position to "AC Output" must be done under settings > meters to make the system correctly accept the change.
