dylan-hyslop avatar image
dylan-hyslop asked
Easy solar 2 3000va wifi signal is very weak
I recently install the Easy solar 2,
The wifi router is maybe 4meter (LOS) from the Easy solar unit, and it shows like 40% signal.
The remote console is so slow its barely useable.
Somethign does not seem correct on this unit with the wifi? Mine also seems to go offline sometimes, it doesn't try and reconnect.
Anyone else having issues like this?
EasySolar All-in-Onewifi
Paul B avatar image
Paul B answered ·
if its a easy solar 2 with a color control then these units don't come with in built wifi and a wifi dongle has been added these wifi dongles can have a low powered wifi unit, so you have to be close, suggest that you connect using a lan cable, or add a more powerful wifi dongle.
I am presuming that the below is what you have
EasySolar 1600 product page
EasySolar-II GX 3000 & 5000 product page
