Franz Voelkl avatar image
Franz Voelkl asked
BMS Error #67
Error Description:
When configuring the Smart Solar MPPT controllers in the CCG on BMS control, an error message is generated after approx. 5 minutes, # 67 BMS connection interrupted.
Unfortunately, I have no idea how and what to set so this monitoring via the BMS is active.
The following devices in use
MultiPlus 24/5000/120-100 431
SmartSolar MPPT 150/85 rev2 V1.39
SmartSolar MPPT 100/50 V1.39
BMV -712 Smart V4.01
Color Control GX V2.30-23
SmartLithium Battery 24/200Ah
I hope you can help me with the above mentioned problem
Thank you in advance
BMS
boekel avatar image
boekel answered ·
What BMS are you using?
and what is the exact type / configuration of the battery / batteries?
Franz Voelkl answered ·
1 x VE.BUS.BMS
4 x Smartlithium 25,6 200Ah
