Is it possible to switch on or off the load output of the mppt in vrm or in the remote console?
I would like to use it to switch on or off remotely.
If it's not possible, would it be possible to implement?
It is not currently possible to manually switch off loads using the mppt.
There are other ways you can buy smart dc switches. Since I don't know you application I have just linked a random one for you to look at and start your search for something suitable for what you want
https://www.amazon.com/MagiDeal-Wireless-Switch-Module-Automation/dp/B073B6PKD9
48 People are following this question.
SmartSolar MPPT 150/85 VE.Can - No current flow in Bulk with PV at VOC
Are 50vdc solar panels wasted on a 12vdc system?
Large difference between solar blanket voltage output and Victron dashboard
Victron Load Disconnect Voltages with Data Cable (no jumper)
Peak Power Pack 40Ah and SmartSolar charge controller - how to connect & setup
