davebrown avatar image
No PV current
I am metering 4.5 amps on the incoming PV wires. 40.21 volts on the input side of the PV lugs. This is a Smartsolar 100/30.
With the bluetooth monitor it sees the voltage but 0.0 amps.
I've simplified the system so that I can diagnose it. I have
one 12v Renogy 100ah lithium battery
Two 100watt renogy mono panels wired in series for 24v nominal
Smartsolar 100/30 charge controller.
When I turn it on or make changes it will move into bulk for 2 or 3 flashes and then to absorption.
Any help?
input current
You have a Voltage of 40 volts on the mppt Input from 2 Serial 12v Panels (24v)???
netrange avatar image
netrange answered ·
What is connected on the Output of the mppt ... 12 , 24 or 48v System ?
davebrown answered ·
I solved it - stupid me. The one wire I was sure was okay was loose.
