jcity avatar image
jcity asked
SmartShunt 500 amp Battery Monitor (Bluetooth) + ASS000100000 Temperature Sensor Not Working
I'm unable to get a temperature reading from the ASS000100000 when plugged into my Bluetooth 500A SmartShunt monitor (red wire from pos battery terminal to pos input on shunt terminal, black to neg input). App only shows "--" for temperature regardless of what I do. Have tried replacing the temperature sensor but with the same results. Bad SmartShunt? I would appreciate any guidance!
SmartShuntTemperature Sensor
seb71 avatar image
seb71 answered ยท
The wire lug should be on the positive battery terminal.
The other end of the sensor should be:
- red wire on "V batt +" at the SmartShunt
- black wire at the "Aux" at the SmartShunt
You also must set the Auxilliary input as "Temperature" (using VictronConnect).
5 comments
jcity avatar image jcity commented ยท
Thank you for the quick reply. It has been connected just as you said, trying both temp probes. Any other thoughts?
0 Likes 0 ยท
seb71 avatar image seb71 jcity commented ยท
The shunt is new?
I see that it displays the battery voltage. But does it measure the current/power/Ah ?
Is the black wire making contact? If you slightly pull on it (without pressing the orange tab), does it stay inserted?
That battery box has water droplets in it. Put the shunt in a water tight enclosure.
1 Like 1 ยท
jcity avatar image jcity seb71 commented ยท
Shunt is brand new out of the box. Measures amperage and power. Black wire will not come out of the terminal block with traction, have adjusted, re-inserted, etc.
0 Likes 0 ยท
Well, if you tested it with two temperature sensors and none worked, probably the shunt is defective.
1 Like 1 ยท
My thinking as well. Thank you for your help troubleshooting.
0 Likes 0 ยท
