Delta Victor avatar image
Delta Victor asked
T sense cable multiplus II
When installing the folowing combination: multiplus II 24/3000/70, smartsolar MPPT100/50, Cerbo GX, smart shunt and battery balancer. I had some questions about the battery temperature sensor. There is a T-sense cable that comes with the multiplus II. The manual says it should be connected to the negative side of the battery pack. Now i will be using a smartshunt, and in the manual of the they talk about a temperature sensor cable ASS000100000. For me it looks the same as the T-sense cable. Is it possible to use the Tsense cable on the smartshunt and let the cerbo GX communicate the temperature info to the multiplus and smartsolar?
Multiplus-IISmartShuntTemperature Sensor
wkirby avatar image
wkirby answered ·
The temperature sensor for the SmartShunt is different from the one supplied with the MultiPlus.
For the SmartShunt you need ASS000100000
