I've got 2 Optima Blue Top D34M batteries wired in parallel for 110 amp hours. But I can't find specs for settings on the Victron for:
Charged voltage
Discharge floor
Tail current
Charge direction time
Peukert exponent
etc.
Charged voltage
Discharge floor
Tail current
Peukert exponent
etc.
Victron do not have all battery types stored in their software, there are simply too many on the market. The Manufacturer should have some recommendations for you though.
https://www.batteryking.com.au/pdfs/battery-king-optima-blue-top-D34M.pdf the info you need is linked. except the peukerts it is probably 1.25 leave the tail current at 4%. Only change those settings if you care having charge synchronization issues.
There is also this site - https://thebatterybase.com.au/how-to-recharge-optima-batteries-with-a-battery-charger/
https://www.youtube.com/watch?v=8yetV6zBO9E maybe check out the video to help with setup.
23 People are following this question.
