Should I modified the settings in a Orion Tr Smart if I use lithium batteries?
Which parameters should I use?
Thanks
Thanks
Hi @Carloa,
it depends on what your battery manufacturer recommended for your Lithium battery.
But you're not going wrong if you choose the Lithium Iron Phosphate LiFePO4 setting, which gives you a charge voltage of 14.20V and 13.50V for float.
Great, thanks.
BTW, batteries are BattleBorn
You always can adapt settings of the LiFePO4 profile for your needs.
For Battleborn I've found this:
Charge settings for Battle Born batteries:
The maximum discharge rate is 100 Amp continuous, 200 Amp for 30 seconds, and about 500 Amp for 1/2 second for cranking and such.
Orion-Tr Smart Dc to DC Charger, Alternator Victron Energy
__________
Orion-Tr Smart DC-DC Charger Isolated 12 / 24 Volt- Product Page
Orion-Tr Smart DC-DC Charger Isolated 12 /24 Volt - Datasheet
Orion-Tr Smart DC-DC Charger Isolated 12 /24 Volt - Online Manual
__________
Orion-Tr Smart DC-DC Charger Non-Isolated 12 /24 Volt- Product Page
Orion-Tr Smart DC-DC Charger Non-Isolated 12 /24 Volt- Datasheet
__________
Victron DC to DC Converters Product Range
33 People are following this question.
