allen-upward avatar image
allen-upward asked
MPPT 150/100-Tr VE.Can CAN address reset (to 0x24)
Hello -- we are using a single MPPT 150/100-Tr VE.Can devices to talk to our system via CAN and they typically show up as address 0x24 on the CAN bus.
  • FW version: 3.02, Bootloader: v1.06, Serial: HQ2042PV6UC
During some bench testing with 2 devices, one of them auto-addressed to 0x25 and we'd like to get it back to the original 0x24 address.
  1. Does anyone have an idea how to do this?
  2. Is there a place to download a manual copy of the v3.02 firmware to try updating it to the same version to see if this helps?
(Note: using the 'factory reset option' via the VE.Direct port did not achieve the address reset to 0x24.)
Many thanks for your help in advance,
Allen
MPPT SmartSolarfirmware updateVE.Can
Hi, if there is a way to do this (I dont know for sure) then it will be by standard J1939/N2K messages.
There is a lot on the internet about this, search for j1939 acl.
or for n2k acl.
and note that just like you shouldnt rely on an ip addresses being static in a dhcp network, you should rely on a network address to be static in a j1939 canbus network either.
so the proper solution for your issue is monitor / scan the canbus to see what address the device you’re looking for is on (by sending a acl message or something like that) and then listening to the responses and using the then found network address going forward.
allen-upward avatar image allen-upward commented ·
Many thanks for your assistance. Will pursue those options.
