philippoo avatar image
philippoo asked
VE.Can communication?
Dear community,
I'm planning to get me a SmartSolar MPPT 250/100-Tr VE.CAN as charger for my 48V LiFePO (DIY).
2 questions:
a) How to connect the device to my home automation (without cloud/Internet) for monitoring and evtl. settings (e.g. charge current limitation)
Is it possible to use the VE.Can with a common CAN adapter? Where to get a 'datapoints description' (evtl. EDS)?
Does Modbus TCP work with this device? Other options, e.g. MPPT?
b) Is it possible to limit the charger to do only e.g. ca. 85% SOC, usually done by reducing the target / charge cut-off voltage?
Schoud I use a certain BMS for better 'collaboration' of the cahrger and the battery?
Thank you very much for your help!
Greetings!
Phil
MPPT SmartSolarVE.Cancharge current limitcommunication protocol
Mike Dorsett avatar image Mike Dorsett commented ·
In order to properly manage the charging of lithium batteries, the BMS must be able to communicate with the system chargers, this is usually done through the Venus OS with DVCC.
Alexandra avatar image
Alexandra answered ·
MPPT product page
VictronConnect manual
PWM or MPPT
MPPT calculator
MPPT codes
