miya avatar image
miya asked
Victron Smart LifePO4 - Parallel Install - Battery Wire Lengths
Hi All
I am installing 3 smart LifePO4 batteries in parallel. Reading "wiring unlimited' - I am aware the battery wires (from batteries to busbar) must all be the same length.
Does anyone know if I can make -Ve and =Ve wires different lengths ?
Due to the orientation of the batteries and busbars - it would be great if I could make the 3 -ve wires 70cm and the 3 +ve wires 100cm. All -ve wire the same length (70cm) and all +ve wires the same length (100cm).
Thoughts or comments ?
Many thanks, Tim
battery chargingLithium Battery
seb71 avatar image
seb71 answered ·
Yes, you can. No problem with this.
miya avatar image miya commented ·
Many thanks for quick response Seb71 - cheers.
seb71 avatar image seb71 miya commented ·
Just make sure you fuse each positive battery wire.
miya avatar image miya seb71 commented ·
Thanks mate - yep - the batteries are being wired in to a Lynx Power In (modified to take Mega Fuses) - so all batteries will be fuses. Thanks again.
Battery Compatibility
