aphpta avatar image
aphpta asked
how to restore batt min value on app
My RV system is working fine but 5 days ago my 100/30 MPPT showed a batt min value after a reset to default, since then this value has disappeared on the app.- see upload below. Pls can anyone explain how to restore this reading. Thanks Peter
Days ago Date Yield(Wh) Consumption(Wh) Max. PV power(W) Max. PV voltage(V) Min. battery voltage(V) Max. battery voltage(V) Time in bulk(m) Time in absorption(m) Time in float(m)
0 28/02/2021 30 10 27 65.36 0 14.41 33 4 279
1 27/02/2021 60 0 90 67.89 0 14.41 1 45 491
2 26/02/2021 40 30 34 66.67 0 14.6 60 1 564
3 25/02/2021 60 40 83 65.69 0 14.27 121 2 628
4 24/02/2021 80 10 20 63.51 0 14.16 124 12 628
5 23/02/2021 50 0 60 67.24 12.94 14.33 27 1 537
VictronConnect
Maybe you have a loose connection somewhere between the MPPT and the battery.
Why did you reset the MPPT to default? Did it have some issue?
aphpta avatar image
aphpta answered ·
Tnx Seb, I did reset as an attempt to restore batt min values as was showing 0 also before reset; I 'll check all connections
Peter
