johnjnr avatar image
johnjnr asked
How to check error codes for Multiplus 12/1600/70
Hi all,
First time poster here.
My battery setup
  • 400ah Victron smart lithium
  • VE Bus BMS
  • VE Bus AC Detector
  • BlueSolar MPPT 100/50
  • Multiplus 12/1600/70
  • Victron Smart Shunt
I have started to have issues with my Multiplus 12/1600/70.
When I start the Multiplus with AC connected and battery at 90% SOC the LED status show
  • Charge: Solid Yellow
  • Alarm: Flashing Red
The multiplus does not charge but it does pass through the power to external AC sockets
When I disconnect the AC power the inverter does not come on and the LED's are all blank.
I have checked wiring to multiplus from battery and the internal fuse and all is OK.
Unless somebody has a good idea I think I should try and get some error codes from the Multiplus.
Can anybody confirm I can achieve this with a PC version of Victron Connect and Interface Mk3-USB?
error
