theorangee avatar image
theorangee asked
GARMIN OVERLANDER with VICTRONCONNECT
Hi Community
Have anyone tried to manage Victron devices using VictronConnect installed in a GARMIN Overlander (which is an Android Device).
I managed to download and install the VicConnect App, the app recognize the presence of a Victron device but then I am unable to actually perform a full connection and management of the devices.
Any Idea why?
Thanks
VictronConnect
jsackspot avatar image jsackspot commented ·
Hi, how did you end up getting the APK installed? What steps did you take? Thanks!
jsackspot avatar image jsackspot jsackspot commented ·
If anyone was wondering how to install the Victron app on a Garmin Overlander, go to APKPure, scroll down to 'Old Versions' and select the latest version. From there, scroll down to find 'Variants', and select the armeabi-v7a version to download and install. This also works with other apps that may not have installed with a 'regular' .apk.
Thiemo van Engelen (Victron Energy staff) avatar image
Thiemo van Engelen (Victron Energy staff) answered ·
What happens when you try to connect?
If it "hangs" at 80%, then it is waiting for a pin code. On samsung phones, a pin popup is shown. On other phones, a notification is shown in the notification bar and that has to be clicked to be able to fill in a pin code.
Kind regards,
Thiemo van Engelen
theorangee avatar image theorangee commented ·
Dear Thiemo.
Thanks for your interest. I am able to connect to different Android phones and IPhones. But not with the Garmin Overlander.
With the Overlander the devices are detected and recognized:
but it tries to connect coing 2 or 3 times from 20% to 80% and back to 1%....
after a while a message comes out telling that it is not connecting and I should try to work on the BT pairing setup.
Matthias Lange - DE avatar image Matthias Lange - DE ♦ theorangee commented ·
Please go through this troubleshooting:
https://www.victronenergy.com/media/pg/VictronConnect_Manual/en/troubleshooting.html
There seems to be a problem with the PIN code pop-up.
Although this is normally not advised, you could try to connect/pair with the Victron products from within the Android Bluetooth menu. Perhaps then it is able to show a popup.
If this is still not the case, it might be that some other app is "hijacking" the pairing/pin popup. I would advice you to check what other apps are installed that can do something with bluetooth devices and (temporarily) remove them.
Kind regards,
Thiemo van Engelen
