bartpoot avatar image
bartpoot asked
Orion Smart Tr DC DC charger and blue smart charger in parallel?
I have 2 ways to charge my leisure battery, one via shore power and one via the car batt.
Can i connect both chargers in parallel to the leisure battery? Should i install a relay to make sure the not-operating charger is isolated from the circuit?
Can i consider the orion smart dc dc charger as an isolator between the car and leisure battery? Or should i put a physical relay/isolator as well?
If i use the ’engine running detection’ can i consider the car battery isolated from the leisure battery when the engine is off? Or is this too much trust in the system?
Orion Smart-TR 24/12 30 DC-DC charger (non isolated)
Blue Smart IP67
Thanks for the help
chargerorion-tr smartOrion DC-DC Converters not smartdc isolators in parralell system
Bob K avatar image
Bob K answered ·
"Can i connect both chargers in parallel to the leisure battery?"
I do. If both are programmed properly for the battery type, they'll both adjust their charging profiles based on the leisure battery's voltage. No concerns about feedback into either device.
"Can i consider the orion smart dc dc charger as an isolator between the car and leisure battery?"
Yes. The DC charger is a one-way charging device and one of its functions is to isolate the starter battery from the leisure battery.
"If i use the ’engine running detection’ can i consider the car battery isolated from the leisure battery when the engine is off?"
I believe you mean "Engine Shutdown Detection". If that function is programmed correctly, the charger will turn off when voltage drops (when you turn the car off) and won't turn back on until you turn the car back on. Then yes, your starter battery and leisure battery will be isolated from each other so that you don't deplete your starter battery.
There's a very small standby current once shutdown is detected. Manual says under 1mA.
