rodgerd avatar image
rodgerd asked
Multiple SmartSolar MPPTs and DVCC - What set the power output?
In an installation with a CCGX and multiple SmartSolar MPPTs each MPPT with the same spec array and exposed to the same incoming solar what will determine the power produced by each MPPT?
Is it just down to small differences in physical installation? e.g. cabling or variation in actual panel output. Or is there something happening within the DVCC algorithm to control power output in each MPPT?
MPPT ControllersCCGX Color ControlDVCCmppt charging
