On a recently acquired boat, I would like to replace my six AGM deep cycle 335Ah 6V batteries with three ACES AL12V400HFA-BT LiPo 400 Ah batteries. These batteries have internal battery management, and the following specs (per cell, and there will be three of them):
ACES AL12V400HFA-BT Li-Po
capacity 100 Ah
Cont. Discharge Current 100A
Peak Discharge Current 350 A
Max charge current 100A
Rec. charge current 10-50A
Nominal Voltage 12.8v
BMS cutoff voltage 10v (internal BMS)
charge end voltage range 14.2 - 14.6v
charge characteristic CC / CV
I would like to know if the following battery charger will work with these batteries:
Shore Power charger/inverter:
"Victron Phoenix Multiplus 12v 3000VA 120A VE.Bus Inside”
If not, I would like to know what equipment changes need to be made in order to use the LiPo batteries.
thanks
Bruce
