brent626 avatar image
brent626 asked
CERBO canbus to REC BMS Wiring
I want to connect my Cerbo to a REC BMS. REC uses a DB9 and has power on pin 9. Searching information in this forum I found the pinout for CAN, but it only shows the signals and ground. Is there a power line on the VE.CAN?
Pin 3 - Ground, Pin 8 Low, Pin 7 High.
cerbo gxBMSwiringVE.Can
Hi Brent, you only need those three.
