Fra avatar image
Fra asked
Smartshunt Charge Efficiency percentage
Good evening, I ask another question about the recently purchased Smartshunt.
The Smartshunt compensates the count of the charged energy with the parameter "charging efficiency".
This parameter is default 95% for Pb batteries.
Currently in my Smartshunt there are 3.2kwh of energy charged, and 2.8kwh of energy discharged.
This is much less than 95%.
Why?
Does this mean that the actual efficiency of my battery is around 89%?
Or does it mean that the Smartshunt uses this parameter in other values and not in this data (energy charged / discharged) ??
SmartShunt
lehrling avatar image
lehrling answered ·
Efficiency is another one of those moving targets, changes with depth of discharge I believe.
I read from someone more knowledgeable here that efficiency should be set lower to around 85% for lead acid.
I personally don't think a battery monitor will ever be bang on, can probably make one crazy trying to make it so!
Fra avatar image Fra commented ·
hi, i agree completely with what you say.
But I don't understand why the Smartshunt, set at 95% efficiency, signals me a very large difference between discharged energy and charged energy.
That is, it indicates about 89% efficiency.
Is this why am I wrong?
In other words, the charging efficiency parameter set is not reflected on the "discharged energy" and "charged energy" values?
I don't know if I explain myself, I know very little English and I help with Google translate ....
