I'm helping a friend setup a Victron system and paying $30 for a USB cable is painful and a hard sell since we have to buy them for every device to connect it to VenusOS.
Are there any generics of these cables?
USB to VE.direct cables should not be necessary to connect every Victron device to a Cerbo GX?
I have no insight into the price of the cable sorry, but they are not usually necessary at all - and often there is another way to design the system that does not require them.
VE.Direct to VE.Direct cables are very cheap, so are CAT5/canbus cables - and they should able to serve 99% of installations.
Please read this post as it explains why QUALITY is important
https://community.victronenergy.com/questions/48562/vedirect-diy-cable.html
I'm not talking about self made cables, I'm wondering why victron needed to create a proprietary cable to data transfer and charge $30 for it when there are many other universal options out there that by _no means_ sacrifice quality
22 People are following this question.
VE Direct to USB data to VRM Portal Advanced Tab
Smart Solar Mppt Control Display - RS232 adapter to ve.direct
Can I use VictronConnect and VE.Direct to USB simultaneously to BlueSolar MPPT
CCGX not showing USB-VE.Direct Devices anymore.
VictronConnect cannot connect to SmartSolar MPPT150/85 when VE.Direct cable attached
