Pylontech batteries sitting at 15c degrees on ccgx,however the VRM is indicating -273 c degrees!
@Mark just checked your case and it seems your VE.Bus reported an invalid value for the temperature a while ago. The solution in this case is to reboot the GX device, that will make the stale value go away
@Teun Lassche (Victron Energy Staff)
under the ve-bus summary,battery temp is still displayed as -273 C even after multiple reboots!.
@Mark Has this issue been resolved yet, as I have exactly the same problem and despite multiple reboots the temperature remains at -273.
25 People are following this question.
