streff avatar image
streff asked
Phoenix 24/250 inverter
Hello, Are the phoenix 24v inverters output either 120 or 230v with a simple adjustment? The description table seem to indicate that. I want a DC 24V to 230VAC NEMA inverter, 180 or 250W would work. I can find plenty of 24v to 120VAC but not 24v to 230VAC.
Any guidance or comments would be much appreciated.
Streff
Phoenix Inverter
@Streff
No they can only output 230V or 120V.
The 230V can only 230V and the 120V model can only 120V.
If you need 230V and 120V you have to buy two inverters.
Justin Cook avatar image
Justin Cook answered ·
Hi @Streff, welcome to the Community!
I will add a couple of things to the previous answer:
The NEMA 5-15 plug is US 120vAC; there is no 230v NEMA plug.
If you're looking for a 24vDC/230vAC 250VA (VA, not watt) Phoenix inverter, the part numbers for those are:
PIN242510100 with an IEC plug
PIN242510200 with a Schuko plug
PIN242510300 with an AU/NZ plug
PIN242510400 with a UK plug
Again, a NEMA plug is not available in 230; that is US 120 only.
streff avatar image
streff answered ·
Thank you very much, Justin & Matthias. Your guidance is much appreciated.
Happy Holidays
