Rob avatar image
Rob asked
internal red led always on in EasyPlus Compact 12V/1600VA/70A
Inside the red led is always solid red. See Appedix B user manual: https://www.victronenergy.com/upload/documents/Manual-EasyPlus-1600-EN-NL-FR-DE-ES.pdf
But how to get rid of it? I am not using the relay. Do I need the Victron VE.direct to USB interface cable to solve this or is it not possible to get rid of this red led at all and will it always be there?10837-alarmledmpc.png
BMV Battery MonitoralarmledEasyPlus
What bothers you about the LED being lit?
You need the MK3-Interface to "switch off" the LED.
